Old 06-19-2008, 09:30 PM   #1
pete
help with a chevy
anybody have any suggestions. I have a 95s10 that i cant figure out. it runs perfect at a idol but if you run it above 3500 rpm it starts acting up and dies then its a ***** to get it to restart. after it restarts it runs fine at a idol again. it has a new fuel pump, fuel filter, rotor button, wires, cap, pu coil, any ideas would be greatly appreciated thanks pete
pete is offline   Reply With Quote
Old 06-19-2008, 10:32 PM   #2
We have a 3500 van at work that goes through fuel relays like crazy. We have checked the entire fuel wiring system and replace the pump but that didnt help. Check the relay. Maybe its on its way out.
Old 06-20-2008, 09:40 AM   #3
JasonCJ7
Throttle Jockey
JasonCJ7's Avatar
Check the fuel filter, it may clogged and cause a fuel restriction.
Old 06-20-2008, 09:48 AM   #4
icemanjes
Icemanjes
icemanjes's Avatar
Images: 169
Check your ground wires also.
icemanjes is offline   Reply With Quote
Old 06-20-2008, 10:04 AM   #5
fuel pressure regulator ?
Old 06-20-2008, 11:59 AM   #6
damn thing will idle there forever, starts right up every time unless you killed it with higher rpms the last time. purrs idling, no miss or anything. has me stumped too.
