Balance A Super Swamper I need help
I just put on a set of S S LTB's 33x13.50x15 and they shake so bad I am thinking about taking them off. They will not balance on my balancer it wants me to put on like 30 oz of weight...... Can anybody tell me if they can be balanced or am I stuck with the shakes.......
cincykid |
They make bb's to put in the tires to balance them.
Call around to a few tire places they should be able to hook you up. I know some guys just use real bb's. |
Airsoft BB's
www.buckeyejeepers.com
Yep, I put airsoft bbs in my 38s on H1 beadlocks and it worked well. I just picked them up in wal-mart. 30oz does seem like a lot though, I put 16 oz in mine and that was more than what I thought would be necessary.
Try rotating the tire on the rim and see if that brings it closer.
So just put plastic bbs in the tire and that will balance the tire? How dose this work? How much in each tire?
use 6 oz per tire of Air Soft pellets . That is about 1/4 of a zip lock bag full ( Ha I said quarter bag ! ) . I have run them in my Iroks since new and they balance great even at high way speeds.
#7 | |
Here is a chart that may be helpful http://www.innovativebalancing.com/BigTirechart.htm Seems to call for 8 oz, I would put 10 oz myself to be safe.
Storm Chaser
We use Equal packs at our shop and they work very well. I've used them in 40's, 24.5 etc with no problems.
http://www.imiproducts.com/equal/index.aspx |
wish i had put some in mine before bolting them all together... really want to balance them, but dont really want to break them down again...
maybe i will do a water/antifreeze
I also just put the regular ol' BB's in my 39.5 Swampers, and several others I know use the same method with good results. I had mine up to about 45-50 mph this weekend coming back from the trail (10 psi in the tires) and would only get a very mild vibration every once in awhile.
#11 | |
need to worry about balanced tyres ? Come on you can tell us. fall crawl ?
#12 | ||
