Old 08-19-2008, 01:01 PM   #1
Lightbulb Onboard air system
Who makes the best onboard air system with a small tank and uses 30 amps or less to run? I have a/c in the jeep and have come close to converting it over but really have been spoiled by it. Any companies you know of or web sites to check out? I have seen viair and am looking for others. Thanks, Scott
Old 08-19-2008, 03:15 PM   #2
kilby makes a good kit from what i've heard, not sure what kinda amperage it takes though.
greg
Old 08-19-2008, 03:37 PM   #3
JeepHD
www.buckeyejeepers.com
JeepHD's Avatar
What about a CO2 setup? I have been looking into them some. Lot simpler and have some good advantages. Only bad part would be having to get them refilled. www.powertank.com and www.ultimate-air.com.
Guess it depends on what you plan to use it for the most.
1994 YJ, 4.0, 5 speed.
Old 08-19-2008, 03:52 PM   #4
i'm all about co2 systems... easy and simple, and they work when your vehicle isn't running.
Old 08-19-2008, 04:18 PM   #5
I seem to use alot of air for myself and others. Like to make plastic bottle pressure bombs while taking wheeling pit stops.
Old 08-19-2008, 10:31 PM   #6
RuffedUpXJ
RuffedUpXJ's Avatar
I ended up converting my Saden stock AC compressor to be an OBA compressor and so far everything is running great. I put an oiler and a filter in so that it runs correctly and I have a 5 gallon tank that supplies enough air to bead a tire and a pressure switch that regulates the pressure in the tank. I have two quick disconnect and a 25' hose to reach around with.
I do understand the point of not having the vehicle on to use it sometimes I wish I could have the Jeep off and have air. But the volume I can run beats out the CO2 system and not having to refill the tank s what sold me plus $125 total for the system is nice.
Old 08-20-2008, 11:03 PM   #7
4RunnerAdam
4RunnerAdam's Avatar
Cant beat the "MV-50" superflow sold at Pep Boys for $60.
Here's a write up on how to port the head and make it work even better. After the mod, it will fill a single 33" tire from 18psi to 35psi in just over two minutes.
http://www.4x4wire.com/index.php?opt...ects&Itemid=83
I've got 2 that I plan on running together with a 5 gallon tank.
Old 08-23-2008, 03:41 PM   #8
I have an extra York 210 compressor, would make a nice OBA with a bit of fabrication..
It's a V-belt with working elec. clutch..I'll let it go cheap!
Old 08-23-2008, 06:21 PM   #9
Thanks for the offer. I have 2 extra compressors already. The engine bay already has one for a/c and is getting tight for space with the coilovers in the way and other junk. I am leaning towards CO2 from ultimate air now.
Old 08-25-2008, 08:07 PM   #10
Grubbi
TS President
I've got a beverage tank from Sparkling Carbonic as Wilson1010 mentioned. Works well and the price was right. I might have about $130-$140 dollars in the whole setup.
'99 TJ
Terrain Stompers Jeep Club
Grubbi is offline   Reply With Quote
