Old 08-25-2008, 10:12 AM   #1
Dana 60 Shaft Upgrade
Who makes strong 60 ford kingpin front inner axle shafts. Want to replace both inners and leave the outers stock. Longfield makes some nice ones but are pricey. Superior and moser probably do but do you order them from some other company or through them direct? I have mosers in the rear 60 currently. Wonder about a warranty also. (I may break one in WV) Like to buy locally if possible. Thanks, Scott
Old 08-25-2008, 10:37 AM   #2
kyrel69
well I know I am going to spend the money on the Longfields b/c you get the inner and outer and the "joint". If you price all 3 they are just a little more but the longfields give you more turning the the U-joint shafts. Also the longfields do not get weaker when you have the wheel cut.
But if you want U-joint shafts. Then I would go with Alloy USA 10 year no matter what warranty.
I think with good U-joint and 35 spline inner and 30 spline outers you are going to break the outer first most of the time. Next will be the ears or the u-joint
Old 08-25-2008, 11:31 AM   #3
Outer is what I want to break. Don't want the weak link to be the ring and pinion which is a pain to trail repair. I may go with 35 inner and outer though and make the flange the weak link.
Old 08-25-2008, 12:07 PM   #4
Alloy USA all the way. great warranty and great service.
Old 08-25-2008, 01:13 PM   #5
If you are wanting to stay with stock 30-spline outers.......don't. They are by far the weak point, especially if you are looking at chromo inners and possibly bling u-joints. I broke 3 stock 30-spline outers (seemed like everytime I went out) with just standard 35-spline Spicer inners and regular Spicer joints, including a 1310 joint in the driveshaft.
If you want to keep a weak spot (fuse), put it in your driveshaft u-joints. Driveshafts are by far the quickest and easiest to replace on the trail.
Old 08-25-2008, 02:08 PM   #6
The front driveshaft is not overkill already. I use your same logic with driveshaft as being the weak link. I have warn outer lockouts and may just replace all the shafts and add flanges but do not want to break the ring and pinion. 5.38 ratio.
