Old 09-01-2008, 10:59 AM   #1
maddhatter
maddhatter's Avatar
Has anyone put a CJ7 on a 79 Bronco frame?
I have a 85 CJ7 and a 79 Bronco and am thinking about doing the swap.
Any input as to why or why not to would be great.
Thanks.
Old 09-01-2008, 05:36 PM   #2
Turn the bronco into a truggy and sell the jeep.
Old 09-01-2008, 06:45 PM   #3
maddhatter
maddhatter's Avatar
Said the guy in the Jeep!! LOL
Can't, had it to long and been to many places with it. It's faimly.
Old 09-01-2008, 07:25 PM   #4
OH-cj5
OK sell the bronco and find all GM parts!
OH-cj5 is offline   Reply With Quote
Old 09-01-2008, 07:47 PM   #5
Put the diffs in the CJ ... I've seen a couple jeep tubs on K5 chassis and they look like ****... I can't imagine that Bronco frame would look much better.
I think the 78-79 Ford D44's had cast radius arm mounts which can be difficult to convert to leaf or coil/air but it is doable.
With the diffs you will need the driver drop 205 and the C6 ... hell you might as well put a 5.0L in it will you at it.
Old 09-01-2008, 08:16 PM   #6
maddhatter
maddhatter's Avatar
HMMM You must know me and know I have a compete and total hatetred for all things GM.
The bronco has a BB 351 M / 5 speed / and a 205 / I don't want to change the front set up I will just move the arms to the outside of frame make them longer and mount them at the frame with himes. It's not a TTB set up. It's a soild axle on coils. Conyers rig is set up this way and it's Flexy as H*ll. For the back A 4 link on coils set up with the axle under the end of the frame is the plan. If I comp cut the back of the Jeep the axle lines up with the end of the tub. I also have a set of bead locked 36's just waiting to be used. The Bronco also has a 6" lift on it already.
Old 09-04-2008, 06:42 PM   #7
I might be interested in the lift kit if you part it
