Guest
Posts: n/a
SOA pro's and Con's
Greetings
Thinking about haveing a SOA on my 90 yj Looking for input about the pro's and con's of doing this and a shop who can do this for me thanks all |
Fine with good strong springs, under 400 hp. and 40's. This is done all the time and is a simple swap with kits available. Armstrong automotive or Complete offroad for work.
I went with lift springs on mine and if I could do it over (and I will) I would have done a spoa on stock (more flexy) springs.
Jeepless
Let's face it a lift is a lift is a lift there is only one pro.
Pro's - more lift Con's - axle wrap, could end up with to large a tire for axles, slip-yoke eliminater required, the extra $$ to make all the little things right. if incorrectly done: bump steer, steering linkage binding, break line failure, death wobble, drive shaft come apart if done correctly: $$ to do it right the first time. |
