Old 09-04-2008, 06:27 PM   #1
maddhatter
maddhatter's Avatar
Can anyone here make these for me?
I need some soild tube stock with a Lt tap on one end and a RT tap on the other. What I want to do is screw one end on the the link arm and a heim joint into the other end to make the arms longer so that they can be mounted on the side or bottom of the frame with a heim.
Old 09-04-2008, 09:21 PM   #2
Custom radius arms with like 1 1/4" joint on each end..?
Old 09-04-2008, 10:26 PM   #3
maddhatter
maddhatter's Avatar
Well I want to keep the arms stock if I can so if they do snap there easy to find. I want them stock at the axle and where there a though bolt set up now I would like to screw on and adapter with a heim on the other end.
Then mount that on the frame.
Old 09-04-2008, 10:31 PM   #4
Welding to those stock cast arms will take some time and skill to be done right.
Old 09-04-2008, 10:39 PM   #5
No welding... they thread on
Old 09-04-2008, 10:52 PM   #6
maddhatter
maddhatter's Avatar
Yes. Thats right Conyer did his by welding them but if they ever brake he would have to fab up a whole new arm I am thinking this way there stock arms and easy to replace. I did find a pic of Conyers setup It flexes way better then most might think it would.
Old 09-04-2008, 10:38 PM   #7
I see, little tiny adjuster links .
Each little link would have a RH taped hole for the existing end of the stock radius arm and on the other end would have a LH taped hole for a heim.
When you buy your joints get them with weld in bungs and the rest should be easy.
Assuming the thread on the radius arm is easily duplicated.
I have some solid 2" stock
Old 09-04-2008, 10:56 PM   #8
maddhatter
maddhatter's Avatar
I am looking into what the thread is now.
Old 09-04-2008, 11:06 PM   #9
Bad thing is your now using the that threaded part of the arm to hold the rigs weight , Ford intended those threads to retain the arm in the bushing socket not hold up 3,000 lbs.
