09-12-2008, 12:14 AM | #1 |
80-120 dc air switch
Where can I find a dc air pressure switch for 80 -120 psi. ? Making another onboard air setup. I need it to turn on and off the jeep compressor when it goes from roughly 80 to 120 psi. and it needs to be d.c. also. Last time I did this I found one on ebay but have had no luck recently. Trying to get this done before the W.V. trip! Thanks, Scott
09-12-2008, 02:10 AM | #2 |
anywhere but there
most air pressure switches are just a mechanical type relay and will run on any voltage. check mcmaster-carr. they should have what you need and you can get most things by the next day with ground shipping.
09-12-2008, 07:44 AM | #3 |
Looked on their site first and found nothing that was DC. Also found nothing in my range of psi. either.
09-12-2008, 10:14 AM | #4 |
www.buckeyejeepers.com
09-12-2008, 10:18 AM | #5 |
grainger is where i got mine
09-12-2008, 10:22 AM | #6 |
