The Physics of Jars and Butterflys
So I have a sealed jar with a butterfly inside.
1. Is the jar heavier with the butterfly sitting on the bottom or side? OR 2. Is the jar heavier with the butterfly flying around inside the jar? OR 3. Its always the same weight regardless if the butterfly is sitting or flying Discuss... I was told I can ask for outside help on this homework project so do it well since I get a grade on this ![]() Thanks! AARON
91 MJ Under construction |
Poor Bastard
[QUOTE=MrShoeBoy;18080]So I have a sealed jar with a butterfly inside.
1. Is the jar heavier with the butterfly sitting on the bottom or side? this one OR 2. Is the jar heavier with the butterfly flying around inside the jar? the weight is not measurable OR 3. Its always the same weight regardless if the butterfly is sitting or flying. the mass is always the same but not the weight i'm guessing but it makes sense to me ![]()
if you can't fit it....FORCE IT!!!!!!!!! |
3
Substitute jar full of water with a fish inside and it will be more apparent. Of course, if you are just asking about the jar as opposed to the jar, butterfly and air, answer is teh same, reason is different.
Unimog 406 XJ with a bunch of stuff put on by somebody else Last edited by wilson1010; 09-25-2008 at 02:58 PM. |
Weight is the same flying or not. When the butterfly is flying the wind pressure exurted from the flapping wings will be the same as the weight displaced from the butterfly sitting on the bottom. Mythbusters on the discovery channel just covered this I believe with pigeons in a semi trailer. Now go finish your homework.
Poor Bastard
never thought about the pressure from the flapping wings. you guys are right... i guess wisdom does come with age!
#7 | |
The Pirate
Really? :(
#9 | |
<Sigh>, I miss Scottie...
Im working on it! Grad school is hard, I mean butterflys and jars! Who knew :p
Thanks for the replies guys! I was thinking it would be the same since the amount of air displaced inside the jar was the same regardless if it was flying or sitting dead on the bottom. Just had to double check with all you old wise guys on here ![]() AARON
