Old 09-29-2008, 09:35 AM   #1
4.6 I-6 stroker motor
Anybody build one of these or know of someone who has? I am trying to figure out what all is needed. Here are a few items I know that I need.
4.2 crank
new rods
new pistons
bore out of 4.0 block
20% larger injectors
head work
computer upgrades?
I have a 1995 wrangler 6 cyl. with low oil pressure and need to do a repair and figured to maybe build another motor while I nurse the one currently in the jeep through winter. I need to find a similar motor to build from 1993 to 1995 I think? Some companies want no less than 1350.00 for the crank, pistons, rods and gaskets! Gotta be a cheaper route. I plan on porting the head at work and need to find out about building it also. Thanks for any input!
Old 09-29-2008, 09:45 AM   #2
95blackyj
Guest
Posts: n/a
that oil pressure has read the same for 2 or 3 years....
Old 09-29-2008, 09:58 AM   #3
Had it making some rattles recently and put a mechanical guage on it and get not so good readings when warmed up also. No rush to replace it until further signs but want a backup ready! Can't handle downtime from wheelin!
Old 09-29-2008, 03:12 PM   #4
I want to keep appraised of this situation and help you if I can.
I have a spare motor but it is a '92. I have searched this before and the most info has been on a page from the middle east sandbox.
EDIT: Just found this http://www.ajeepthing.com/stroker-motor.html
Old 09-29-2008, 04:44 PM   #5
Titan engines makes a stroker kit complete with block and head for $2,200.00. Some kits that include rotating assy. want 1400.00 for just that! Can't see putting alot of $ in this. Checking on supercharging a stock 4.0 also.
Old 09-29-2008, 05:40 PM   #6
DinkDavis
Dodge Truggy
DinkDavis's Avatar
I have a 89 or 90 mdel XJ 4.o 4speed if it will help runs good 157000 miels just rotted body.
Thats good stuff!!
DinkDavis is offline   Reply With Quote
