Old 10-22-2008, 02:02 AM   #1
1 ton springs in my 3/4 ton
Ok, I want to stiffen up the rear of my 2005 2500HD Siverado 4WD SRW for towing a heavier trailer. I know i can do add-a-leafs, or a timbren kit. But thought why not try and see about swapping in the springs from a 1 ton of the same year or body style.
Anyone ever hear of this? How much more are the 1 ton springs rated for? Is this a good option, or does anyone have a better suggestion?
Old 10-22-2008, 02:34 AM   #2
The guys on a ford truck site I used to frequent swore that the springs were identical between the F250 and 350. Had part numbers from the dealer to back it up, and that the only difference was a 4" block versus a 2" in the 250...
I guess this really means nothing to your 2500, except as a warning that you might not gain as much as you're hoping for...
Good luck...
Old 10-22-2008, 02:50 AM   #3
i was wondering if the springs might be the same... wonder where i could find a definitive answer... dealer i guess.
Old 10-22-2008, 05:31 AM   #4
Airbags...
Old 10-22-2008, 07:42 AM   #5
Airbags are awesome. You can still keep the 3/4 ton ride quality. On dodges the 3/4 to 1 ton springs are a direct swap. I ordered my 3/4 ton with the 1 ton axle and spring package to cheat the city ordinance on parking one tons on the streets and insurance can get more expensive with a 1 ton.
Old 10-22-2008, 10:25 AM   #6
Yeah, airbags seem like a possibility. Jeff, do you just air them up when you have a load on them, or do you keep them aired at a certain psi all the time?
BTW, did you get my PM with the buggy parts?
Old 10-22-2008, 05:38 PM   #7
Nuts's Avatar
Aren't the axles the same on 3/4 and 1 ton Dodges? Or is it just the Cummins trucks that are the same?My '94 3/4 ton and '99 1 ton had basiclly the same junk 60 in the front.
