Thanksgiving weekend
Is a yearly tradition it seems....
is a bunch of the locals going a lot of you guys went last year, hope you can make it back this year. staying at lil abners Li'L Abner Motel & Restaurant, 1000 Natural Bridge Rd, Slade, KY 40376, (606-663-5384)
May go if WV trip falls through! It was coooooold last year :p
I may try to join you for this trip. Got to make sure there are no family obligations for the holiday. Haven't been to Slade in way to long.
'94 YJ |
abners was about full last year
lots -0- drinkin in the evening's if i recall
I remember that too. Remember the cold too. Had a great time though.
you can do it !!!
I'm going, been the last 2 years definately a good time no matter what the weather. Good people + Good wheeling = Good times
87 4runner cut in half 36 swamper beadloks some other bs |
No cold is Helicoptor pad at Harlan in February in a Jeep with no top or windshield. Oh yea it was snowing too.
you can do it !!!
Good weather , has been worse. We are leaving out fri morn how about anybody else from cincy area
i won't be able to make it til sat. myself. will be getting back from fla. about 3:30 sat. morning then finding the willpower to get to abner's in time to ride.
talk about dedication! 1,050 miles str8 thru to fla. there for 1 hour then 1,050 str8 back home just to ride in the cold rain and snow.
ill be there...ready 2 party as usual....
I will be out there somewhere...See you all then.
Finishing it today. I decided to do some maintenance while I had it tore down, so pulled the front carrier and put in a new pinion seal, axle seals, hub seals, grease packed all bearings, changed gear oil front and rear. Checked other heims. Also added a pillow block bearing and crossmember for the rear driveshaft to get it up out of the way. Gotta build the driveshafts today.
#15 |
would someone who is definately going to come down please call me...(859) 595-0305. thanx, boomhauer.
