Hvac
Who is the heat and air guru
I have a rheem classic 90 about 4 years old started in the spring thought it was low on propane but is still doing it this fall will cycle and heat like it should then cycle off next time it will cycle blower will kick on cycle back off b/4 it should, kinda like it runs out o propane ? will cycle on off on off on off several times without lighting, will go in shutdown mode... I guess is what it would be called 10- 15 minutes later will go thru the same **** sometimes it will light and run sometimes it wont thermostat cause this? HELP..
thermocouple
thremowho?
these hard to replace ? where to buy? guess i need model # and name of furnace cost much?
616 5750 Mike sawyer.
same thing happened to ours this past spring to end the season. replaced the whole thing... not sure if the thermocouple is hard or expensive, we just needed a new furnace and didnt want to dump any money into the old one.
yep, seems to still be still working
the way it should
furnace isn't fixed, it is just messin with my head
well at least it's not periodic, doesn't work at all now took what appears to be the flame sensor out sanded, put it back in. has LED's... flashes 4 times then starts what i think is a new cycle doesn't even get to the ignition stage at all pressure switch maybe. looks like the yellow pages on this not sure what else to do here Called the # above but hate 2 keep aggrivating to guy is a far drive for him
Hmmmm I thought he lived around here.
said he lived in harrison
jacked with the pressure switch seems to be working, getting correct volts anyway started jacking with thermostat and it started working again
hvac dude here. back of your furnace doooor should have a chart what those codes mean. if it is your pressure switch not making, check 2 things. when your furnace is tying to light but failing, take your front combustion air (burner) door off. if it lights now, that means youve got a restiction in the intake pipe. leave, birds nest, ect. dosent light? try to clean your trap. if your furnace is a 90% or more, youll have tubes going down from below the inducer motor to a cannister(trap) before out to the drain. take it off and flush it in the sink. make sure you have it primed with water upon reinstall. hope it helps, rob. ive got to pm you about some other stuff, anyway. rob
