FRAME REPAIR?? pics
This guy is pretty much giving away this jeep but MY only concern is this section of the frame obviously. Where would I even start going about fixing this?
i would start by finding someone with good fab skills unless thats you and if it looks that bad there i would look closer at the rest like on the inside of the frame because it would not be uncommen for ther to be more problems
I have decent fabrication abilities I could always learn by trying. The guy said that the rest of the frame is ok , but I am def going to do a good inspection
doesn't look that bad if that's all there is, shouldn't be to hard to weld a couple plates in there.
Yea that is a super easy fix don't freak a couple plates a a couple hours and it will be good as new. I have had to do the same thing to a few CJ frames over the years. Also, make sure you check around the steering box.
Cool that gives me some excitement about getting this jeep. its a 94yj 2.5l ax5 The guy is asking 1200 he says it has some other issues such as the rear end locking up after bout 10 min of driving then it will free back up, brakes? bearings? Its also hard to get into first but shifts fine and the transfer case shifts hard.
