Danny Beach
truck won't start
Bronco won't start
wouldn't start mon. morning and still won't start I thought it might have been frozen gas line with that cold weather but it's getting gas and getting spark what to check next any ideas ?????
86 Ford Bronco |
Jeepless
fuel, spark, air that's all it needs to atleast sputter. Clearify it won't start.
Does it routinely fix itself?
Definitely need more data... ![]()
timing
Danny Beach
more info humm
lets see it cranks over but won't start I don't really know anything else to say I'll try and check the timing I guess the chain could have jumped a tooth
86 Ford Bronco |
Throttle Jockey
Check the other electronics in the distributor. I.e. Cap, rotor, spark module.
Danny Beach
new plugs ,wires, cap, and button got it going also put a new Ignition modual but timing is off it was realy rough and would die I don't have a timing light but I ajusted the distibutor so it is runnung but kinda rought still
so would that mean the timing chain jumped a tooth?
86 Ford Bronco |
