Transfer Case Issues?
I've got a 98 XJ that I'm actually trying to sell. When you engage the 4 wheel drive and turn the wheel, it has horrible wheel hop or skip. It doesn't seem to make a difference if your on dry pavement, snow, mud etc.... It is also rough shifting out of 4 high to 2 wheel drive. I at first suspected the transfer case, but it doesn't make any odd noises when it's skipping and hopping in circles. Which makes me think that it's not the transfer case. Any help would be appreciated.
#2 | |
One of these days Zuk 2.0 |
#3 | |
It does it even in mud and snow? That is odd. Dry pavement's a given, but if there's enough "slip" in the road surface, you shouldn't get that hop... Sorry, I'm not much help, but I'll think on it... Robert
is it possible that somewhere along the way, someone swapped an axle that had different gears?? but they must be somewhat close...
doesn't explain the wheels turned bit of your description, but would certainly account for binding/hopping, and difficulty shifting tcase... are you sure it would act fine in a straight line??
brad ![]() 5.0L | 435 | 203 | 300 | 4.10 | 39.5 Buildup BACK underway... Last edited by KargoMaster; 01-31-2009 at 01:00 AM. |
Aahhh, poop, didn't think that far down the driveline... I was sooo close...
Thanks for the followup, I get to sleep better tonight. ![]() Post up some pics, will help to sell it... Hope they didn't charge you anything to tell you that...
Yep, you were right there!
Glad you got it sorted out... How different were they? Robert
your right its a jeep thing that i dont understand and 92 was the last year for the disconnect so it still wouldnt apply. i like brads thought diff axle gear ratios
One of these days Zuk 2.0 Last edited by Flxratd; 01-31-2009 at 01:28 PM. |
I drove the jeep yesterday in the snow to see if I could figure out anything. It seemed that even in a straight line it would skip occasionally, hardly noticeable but you could tell if you paid enough attention to it. It was also making a loud constant noise, this has never happened. I owned the jeep for a year as a company vehicle and haven't really spent much time personally driving it, so I'm just now figuring all of this out. I know at one time it was wrecked... just thinking... a slightly bent front driveshaft?
check the gearing in each dif... seriously, it sounds exactly like it would act if I put front in low and rear in high...
#10 | |
How bad was it wecked? If it was bad enough to bugger a control arm mount (which really isn't that hard to do) they might have just swapped in a whole junkyard axle. And if they didn't know better, they could've grabbed one with the worng ratio. You don't have to pull the covers and count teeth. Jack it up and rotate the driveshaft. Count how many turns to get one rotation of the tires. Good luck! Robert
I appreciate the help. The gear ratios was a guess of mine as well, it just seemed unlikely that anyone would have changed them. But I'll check into it. Thanks again.
Now I'm curious... wanna know if that was it... (pacing nervously)
