02-10-2009, 09:53 PM | #1 |
Leafspring again!
OK peeps, I broke another leafspring :( (the driverside this time) front eyelet.
I've seen a few mentions of using the leafs off of a dodge van but not what kind of dodge van. Does anyone have that info?
Romans 7-8 |
02-10-2009, 10:42 PM | #2 |
Guest
Posts: n/a
I used the leaves from a mid 90's dakota pickup to get 4 inch of lift. I had to use my xj main spring and I cut the dakota main spring to fit and used all but the overload spring from the dakota pack. not sure about van springs though
02-11-2009, 07:31 AM | #3 |
Jeepless
sounds like you may want to stop buying things from a junk yard and get something with a warranty. like into military wrap springs.
02-11-2009, 08:00 AM | #4 |
so I need to take the whole Cherokee back?:confused: Since they are the stock springs that came on the rig.:( and I got the last replacement from Sarge. (many thanks again Sarge) I've read about the dakota springs but some where out there is info on using a van leaf because it is longer behind the centerpin and gives a better rear shackle angle. Someone out there knows!
Romans 7-8 |
02-11-2009, 08:12 AM | #5 |
Jeepless
I have never heard of a van springs except, Astro/safari coil van springs make a good setup for if/when you want to go coils and linked. I have heard of regular use with waggy, dakota and F150 (these have recently become pretty popular).
Sorry I can't help you any more than that. |
02-11-2009, 12:30 PM | #6 |
02-11-2009, 05:33 PM | #7 | |
One of these days Zuk 2.0 |
02-11-2009, 11:58 PM | #8 |
Man, I just spent 45 minutes reading the NAXJA thread and I still don't have the final solution:confused: but they did mention S10 springpacks also. Thanks for the help guys, I'll keep searching
Romans 7-8 |
