Old 02-15-2009, 09:51 PM   #1
trans. no shift at w.o.t.
I have recently purchased a 2000 dodge dakota r/t from a salvage yard (with a 5.9 360 v8 and 46re auto) and finally got it up and on the road. Problem is that at wide open throttle it revs out and bangs off the rev limiter and will not shift into 2nd until I get off the skinny pedal. If I drive it around at normal city driving throttle it shifts fine. While in 3rd gear if I hammer down it shifts to 1st and again will not shift to 2nd until I ease off the pedal. This is a huge problem because this truck will frequently see w.o.t. at the track. Any ideas? :confused: I am going to adjust the tv cable and see what happens.
Old 02-16-2009, 02:45 AM   #2
throttle position sensor.
mopar +4 fluids.
ask tinbeater he can get answers from
techs at his work...
Old 02-16-2009, 09:45 AM   #3
As you already mentioned, try adjusting the TV cable. That is definitely a sympton of a misadjusted TV cable. If I remember correctly, the 46RE still has bands that need adjusted for normal maintenance but is seems this rarely gets done.
Old 02-16-2009, 10:18 AM   #4
I bet the bands do need adjusted. I have never done this before and the shops I deal with do not like to do this probably due to job security!
Old 02-16-2009, 10:46 AM   #5
Switch to satellite and get rid of cable.
Old 02-16-2009, 10:49 AM   #6
seems obvious now
Old 02-16-2009, 10:59 AM   #7
Satellite is less reliable which is kind of like georges ford! (sorry George! :o )
Old 02-16-2009, 12:08 PM   #8
maddhatter
maddhatter's Avatar
Said the guy with the broke Dodge.
