Old 08-24-2009, 12:50 AM   #1
bc35339
bc35339's Avatar
my new ride
I picked this up sat. and was able to take it to the trails for about 2 hours today.
Old 08-24-2009, 06:00 AM   #2
drmeece
drmeece's Avatar
And promptly put it on it's side.....Got to like that!!!!
I got a jeep
Old 08-24-2009, 08:07 AM   #3
Nice ! details on the buggy ???
Old 08-24-2009, 08:10 AM   #4
x2
Old 08-24-2009, 08:54 AM   #5
Looks like you swapped pane tanks just before the roll, ha.
give us some specs on the rig.
Old 08-24-2009, 09:29 AM   #6
bc35339
bc35339's Avatar
[QUOTE=carwash;26856](Looks like you swapped pane tanks just before the roll, ha.)
(give us some specs on the rig.)
Good eye! That was the first time to swap tanks on the buggy and I had a heck of a time doing it wasent in the best place to be swaping tanks. The tanks that came with the buggy are the steel forklift tanks and are a big differance on weight compared to the alum. 10 gallon tanks I use on my toyota truck. I plan to let the steel ones go with the truck and keep the bigger alum. for the buggy if they will fit. I havent tried it yet.
Heres the list the seller give to me.
•TOYOTA MOTOR
•RUNS ON PROPANE
•TWO PROPANE TANKS
•TOYOTA 5 SPD TRANNY
•MARLIN CRAWLER DUAL CASE ADAPTER
•CHEVY 10 BOLT FRONT AXLE
•CHEVY 12 BOLT REAR AXLE
•LOCKED FRONT AND REAR
•CHROMOLLY SHAFTS FRONT AND REAR
•BEADLOCKS (I THINK THEY ARE MRT)
•42 INCH IROKS TONS OF TREAD
•DISC BRAKES FRONT AND REAR
•STAINLESS STEEL BRAKE LINES
•FULL HYDRAULIC STEERING
•WILWOOD HYDRAULIC CLUTCH
•RACING BUCKET SEATS
•5 POINT HARNESSES
:OPTIMA BATTERY
:REAR SWAYBAR
:2,000 LBS
IT'S 4 LINKED FRONT AND REAR, HEIM JOINTS ALL THE WAY AROUND, AND HAS 18 INCH LONG TRAVEL AIR SHOCKS.
THE WINCH IS A RAMSEY 8,000 LBS
WIRED IN THE CAB CONTROLS.
Something he forgot to tell me is that it has the worse oil leak ive ever seen. Looks like its leaking somewhere around the timing cover I plan to fix it this week
Old 08-24-2009, 09:35 AM   #7
