Old 09-06-2009, 03:43 AM   #1
Axle Swap Complete
I just finished my axle swap. The 8.8 is in. I used the stock yj leafs in a soa configuration, Russell brake lines and JKS quick disconnects. It rides like a dream rather than the log truck it used to be.
One question I have is:
what can I do for leaf springs that are as flexable and soft as the yj's but have additional support at the front eye. (I have noticed a bit of a bend) I cannot tolerate ANY additional height. I had thought about the RE 1.5 SOA springs, but I dont want or need the additional height. Does this leave me with getting custom springs like alcans?
Old 09-06-2009, 07:07 AM   #2
Some spring packs have what is called a military wrap. It is an extra main spring that wraps around the front and rear bolt area. I have had big ****s and old man emu springs with this and worked well. Congrats and good luck!
Old 09-06-2009, 11:31 AM   #3
Were the leaves new? Is it possible they're just sagging a little, and new YJ springs would give you the ride, height, and arch you want?
Personally, I don't think I'd worry about a "bit of a bend," if it sat and rode right. I'd keep an eye on it to see if it got worse, but I'd just run it.
Good luck!
Old 09-06-2009, 11:51 AM   #4
No, the yj springs were not new. I like the ride height and I am going to run the springs, I was just wondering where to go when the inevitable happened.
Old 09-06-2009, 10:18 PM   #5
Saw you on rt4 today! Looked good!
Old 09-07-2009, 01:27 AM   #6
If it looked good, then it rides even better. I had no idea how much of a buckboard wagon ride the ProComp rear springs were!
Can't wait to wheel it
