Old 09-29-2009, 08:00 PM   #1
Full time vs part time
Just picked up a xj with full time and part time 4wd. What is the difference? If I am wheeling in full time what will happen?
Old 09-29-2009, 09:21 PM   #2
Where are you getting the part time and full time part??
Here's my take on this generic idea... (and I'm no XJ guy)
Full time 4wd means the front driveshaft always spins.
Part time 4wd means the front driveshaft will not spin in 2wd (usually accompanied by lockouts)
You can have one or the other... not both.. but there are also wacky things like a tcase locking device that will force a 50/50 split of power front/rear.... guess I'm still confused on where you're getting the idea that it has both...
Old 09-29-2009, 09:32 PM   #3
jeeptech77
jeeptech77
jeeptech77's Avatar
full time
in a xj the transfercase has what is known as a viscus coupling it is suppost to allow limited slip between front and rear driveshaft
ideally for snow and on pavement use
this is known as part time use
full time operation is when the differential in the transfercase is locked together ( kinda like a spool ) but disenguageable
the older chevy ford dodge had lockouts so the vehicle would not move in part time just like a open diff with wheel off the ground
jeeptech77 is offline   Reply With Quote
Old 09-29-2009, 10:31 PM   #4
But does it make a difference in a offroad situation? Now I would normally leave it in low but I am just curious.
The t-case positions are
2wd
4full time
4part time
N
4lo
Old 09-29-2009, 11:48 PM   #5
From my test drives of XJs, it seems to me that the viscous coupling is active when it is in 4wd Fulltime. This would be the setting to use for slick onroad situations.
Switching to 4wd part-time locks the coupling and it becomes like a traditional transfer case.
The danger in wheeling in "fulltime" is placing a lot of stress on the t-case if 1 wheel were to spin and the rest have great traction.
Old 09-30-2009, 03:11 AM   #6
Close... Just exactly backwards.
The standard XJ case is the NP231. 2WD-4HI-N-4LO.
Engaging 4HI or 4LO locks the front and rear driveshafts together (actually chains them together, whatever...) Great for off-road, not so much on-road.
The optional cases (NP242 et al) have the viscous coupling, and the positions you list: 2WD-4FT-4PT-N-4LO
The 4PT works like the 231's 4HI: Positive engagement.
The 4FT is the one that allows some slip between the 'shafts. Great for on-road, iffy-traction situations.
You already know to use 4LO on the trail.
Old 09-30-2009, 09:55 AM   #7
As mentioned above, 4 full-time is the same basic idea as AWD and you can use this anytime on any condition. However, there is no viscous coupling or any type of limited slip in regards to transferring power between the front and rear tires. The transfer case functions as an open differential between the front and rear axles (we did testing on vehicles equipped with this transfer case for years, and I just glanced through a factory service manual to verify)......no clutches, no viscous coupling, just an open diff....at least for the Jeep/Dodge/Chryler versions.
This means that you can have a "one wheel peel" going on when in full-time 4wd mode, and I've personally seen this. Again, we intentionally performed a durability test on a wetted uphill grade where a vehicle took off at wide open throttle from a stop, which caused only the left front wheel to spin like mad. Also, if you pulled either the front or rear driveshaft the vehicle would not move unless in 2wd or locked in 4wd.
Several versions of this transfer case were used over the years. Included are "4 position" and "5 position" versions in both manual and electronic shift models. The 5 position versions had 2 hi, 4 FT, 4 PT, N, 4 lo. The 4 position versions eliminated the 2 hi option, normally electronic shift, and where used in heavier vehicles like the V-8 Durangos. This version was called the 244. They also tried a 144 version that eliminated low range, but I don't know if that ever made it into production. (Note the name changing from "2" to "1" which denotes 2 gears, hi and lo range, to just 1 gear).
Jeeps did use other versions of transfer cases with various forms of limited slip and viscous couplers including the 249 (optional in the ZJs) and the 247 (optional in the WJ's). Both of these had a direct drive to the rear wheels, and the viscous coupling applied power to the front as needed.....meaning you could pull the front shaft and they would deliver power to the rear wheels with no slippage.
Old 09-30-2009, 09:08 PM   #8
Ok sounds good. So how does this t-case hold up?
And blazerbrad got me thinkiing about something else. Does this mean that in 4fulltime because of a center diff, that it will be either front wheel or rear wheel drive depending on traction?
