Old 10-23-2009, 12:51 PM   #1
77k10
77k10's Avatar
cherokee blower motor
Anyone ever replace a blower motor in a newer cherokee.... i have a 2000 and the heat and air do not work.... was told the blower motor needs replaced. Any help would be appreciated
77k10 is offline   Reply With Quote
Old 10-23-2009, 01:21 PM   #2
it makes a difference if its a regular or grand. the grand is easy under the dash 3 screws unplug the connector and your good. if its a sport its under the hood and they (alldata) are saying that the a.c. will need to be evacuated to relocate the rec/dryer to give you room to remove the blower motor. if that is the case grab a test light and make sure you have power at the blower motor if not check the fuse then the blower resister. if anyone has done this and the a.c. does not have to be evacuated please chime in as i have not personally done this and am going by what alldata says.
Old 10-23-2009, 01:42 PM   #3
Sorry I'm not sure on the 2000..Just went and looked at my son's 99. Sure enough like Scott said the a/c receiver dryer is mounted in the way.. You may try and unbolt the mount and turn the dryer up to clear it.
I looked on NAXJA this was all I could find. Worth reading http://www.naxja.org/forum/showthrea...r+motor&page=2
Good Luck
Old 10-23-2009, 07:53 PM   #4
77k10
77k10's Avatar
my bad it is a xj...... that sucks... and if anyone wants to make some money replacing some ball joints give me a call at 859 250 9560.... not really able to do any work right now. thanks!
Old 10-24-2009, 09:11 AM   #5
I'm interested... Will give you a call.
Old 10-24-2009, 06:05 PM   #6
Trigger
Before you go and replace the motor, make sure it's not the speed control relay. I just had to replace mine because it would only blow on high.
