Old 11-05-2009, 09:49 AM   #1
77k10
77k10's Avatar
cherokee running funny
one of my cherokees just recently encountered this problem. When you first start it it runs real rough almost like its missing... but when you give it gas and start driveing it will start to act normal. And it does not always do this. Any thoughts?
its a 2000 by the way... bone stock, 4.0
77k10 is offline   Reply With Quote
Old 11-05-2009, 06:13 PM   #2
Hmm.... Not alot info.
Check and/or replace the spark plugs.
Good Luck
Old 11-05-2009, 06:18 PM   #3
if you dont know the tune-up history on the jeep i would go one step further and do cap/rotor and wires with plugs. moisture really affects those peices.
Old 11-06-2009, 04:56 PM   #4
jfiscus
jfiscus's Avatar
check your fuel injectors for leaks also, if one is leaking do not start or drive it until replaced.
Old 11-06-2009, 08:22 PM   #5
not into a car-b-que huh. ill bring the burgers
Old 11-06-2009, 08:54 PM   #6
77k10
77k10's Avatar
yea not sure of tune up so im replacing wires and stuff tommorrow... no injector leaks... was thinking maybe a tps sensor or air sensor too tho
