Old 12-03-2009, 11:40 PM   #1
lky13blazer
lky13blazer's Avatar
tire question
does the width of your wheel affect the height of the tire? i have 2 sets of 35's and theres about 1.5" of differance...one sets on 10" wide wheel the other is on 7 or 8"... and the one on the wider wheel is the ones that are shorter..
lky13blazer is offline   Reply With Quote
Old 12-04-2009, 12:24 AM   #2
Rim width does matter a little, but you'll see more difference from brand to brand.
My 35" BFGs are almost a full inch taller (and an inch narrower) than my old Dunlops...
Are all yours the same make?
Old 12-04-2009, 08:01 AM   #3
Yea, what he said....I'd have said make is more of a height difference than width...
Old 12-04-2009, 08:35 AM   #4
RuffedUpXJ
RuffedUpXJ's Avatar
I know my worn BFGs are barely 33.5" tall and they are 35's.
It is more of the brand having differnt heights. Just like TV's they are in a "class" of sizes. So your 50" TV could only be 49.6".
Old 12-04-2009, 09:40 AM   #5
lky13blazer
one set is the old style buckshot mudders the other set are called bigfoots... do you guys think it would hurt anything to run 2 of the shorter ones on the front and the taller ones on the back,i have a k5 blazer..i also was gonna put the shorter ones on the narrower rims to try to get a little more height
Old 12-04-2009, 10:21 AM   #6
you can try that like you said to get alittle more height to match them and if 4 wheel drive is used on slippery surfaces but if you get on a harder packed surface it will put extra strain on the drivetrain.
