Old 12-09-2009, 01:56 PM   #1
f4isvt
gear help
I have a 89 22re 5 spd manual that currently has 4.10s in it. I am debating putting 4.88s in it as I drive it everyday and once or twice a year it see's the trails (since i am selling the trail rig) I am running 31x10.5x15 is a 4.88 to much of a gear for street use? Or should I switch to 33x12.50 and run 4.88s? I have tried messing with those gear calculators but I dont get it and dont know any info like trans ratios. Thanks
1989 ext cab yota 22re bored .20 over trd cam, trd headers, Marlin crawler front bumper w/stinger, Marlin crawler roll cage, trailgear rear bumper, trailgear rock sliders, richmond 5.29's, and lockright rear, 33 nokian mt's. 10k winch. Rear disc conversion. Chromoly rear axle shafts. Bombproof motor mounts and transfer case mount. Whole lot of rust and scratches.
f4isvt is offline   Reply With Quote
Old 12-09-2009, 02:18 PM   #2
Give me some rpm readings at say acruising speed of 65mph. and one of 40mph and tell me what gear you are in. That is a start.
Old 12-09-2009, 02:20 PM   #3
f4isvt
with the 31 it does 70 at 3k rpm in top gear obviously I am pretty sure I can run 35-40 in 3rd gear at 3krpm
Old 12-09-2009, 02:45 PM   #4
The rpm's seem fairly high but maybe you need that to have enough power to go . Sounds like 33's with the 4.10 setup will take the rpms down to 2500-2600 rpms. That may be nice.
Old 12-09-2009, 02:55 PM   #5
Green Zuggy
Green Zuggy's Avatar
Images: 231
Here's a link with some info that might help you determine what gearing you want to go with...:)
http://www.4lo.com/4LoCalc.htm
Hope this helps,
Jeff
Old 12-09-2009, 03:40 PM   #6
Years ago i wheeled with a guy that had a 88 4runner w/33's and 4.88's...
He always said the highway rpm's were just a little high, but it was really nice for 2 lane driving and trail riding...
Old 12-10-2009, 05:20 PM   #7
Waffle's Avatar
Images: 10
.02
ALWAYS anticipate going to a larger tire. It WILL happen. You wheel it twice a year yet drive it everyday. 4.88 with 31's will be too steep and kill mpg. (we're talking real bad mpg) I used to have 36" iroks with 5.29 and could cruise 70 on the highway at 18-20 mpg.
31's.....4.10/4.30
33's.....4.30/4.56
35's.....4.56/4.88
36+.....4.88/5.29
remember, base your decision as a daily driver. 33"/4.10 w/ smooth rolling radial will work fine. A bit piggish up highway hills, but still ok. Put the gear $$ to something else.
Old 12-10-2009, 08:41 PM   #8
for big tyres and offroad
my vote is 5.29 also
Old 12-10-2009, 10:09 PM   #9
f4isvt
if your doing straight axle I know where a nice set brake to brake front and rear axles are 5.29s detroit front and rear 400 bucks. Anyways the big reason I wonder is I found a set of 4.88s set up for a pretty good price then could sell my 4.10s and recoop a little of my money. My truck is to fast off road unless i put it in 4low but its annoying to run around in 4low all day. I just want to make sure 4.88s wont be too much for the street.
Old 12-11-2009, 08:17 AM   #10
In my opinion, axle gears are mainly to opitimize performance on the street, t-case gearing is to optimize off-road performance. You simply can't get nearly the percent amount of change with axle gears as you can with lower t-case gears or a doubler.
I'm by no means a Toyota guy but we are talking about a little 22R 4-banger and not a V-8 so the powerbands are drastically different. Don't these trucks usually come with 4.10 gears stock with somewhere around 28" tires? I can see how 4.88 and 31's might be slightly low for street driving but it's only a couple hundred RPM at 65 mph higher than stock, which is probably perfect because you aren't just overcoming the added tire height but also the heavier weight and rolling resistance of the tire. I do know a guy in our club that put 33's on his stock 4.10 geared Toyota and 5th gear was completely useless even on flat roads.
Of course my idea of trails are apparently different than the original poster in regards to the comment about using 4 hi so my opinion may not work for him. I can't remember the last time I used 4 hi on any type of trail, if hi range is needed than I don't need 4wd and if I do need to go faster in 4 low I just shift into a higher trans gear. I also wheel regularly with a couple guys in Sami's with 6.5:1 t-cases and they just use 3rd or 4th gear, or even 5th gear, in the open spaces.
Old 12-11-2009, 03:33 PM   #11
I agree almost completely with Brad... percent change through t-case is significantly different than dif gearing...
But I've also been at Haspin on wet/sloppy days where I don't see much of low range all day... if only for additional wheel spin to clean out the tires...
Some great tech throughout...
