01-13-2010, 12:39 AM | #1 |
Dana 30 hub conversion
Can I take Cj outer knuckles and do a hub conversion on my Xj and then put the bolt pattern adapter spacers on the back to make it all work?
01-13-2010, 07:49 AM | #2 |
no,, the ball joint in a CJ go in the outter knuckles and the XJ are pressed into the inner knuckles.
But I did see were someone is makeing knuckles for the XJ(and other jeeps that use that knuckles) that use all the older hub parts |
01-13-2010, 09:29 AM | #3 |
Should have just got a CJ, they last forever.
01-13-2010, 09:59 AM | #4 |
why? I would assume running a full-time front locker?
01-13-2010, 10:49 AM | #5 |
http://www.reiderracing.com/product_...ducts_id=32424
here is a link to the knuckles I was talking about |
01-13-2010, 08:50 PM | #6 |
For now i want to weld it and possibly put some good shafts and joints in. I also dont want to deal with the unit bearings
01-15-2010, 03:14 PM | #7 |
If you have a CJ 30 couldn't you use the inner C's and knuckles on the XJ 30 ??? just an idea .... prolly alot more work then it's worth but an idea.
