01-22-2010, 05:14 PM | #1 |
D44 in a YJ?
A buddy of the owner brought his YJ project intot he shop to get a new clutch. He had me take a quick glance at it since I know more about the modified vehicles than he does, and I noticed that the front steering has issues that need addressed.
Someone has swapped a D44 with an air locker into this YJ, but the steering is rubbing a hole in the tie rod.... What are your suggestions? I suggested a SOA lift kit, but wasn't sure what to do with the steering after that. I assume with a larger lift he'd be running larger tires and would need a stronger steering setup. Take a look at the images below Last edited by jfiscus; 01-26-2010 at 09:54 AM. |
01-22-2010, 05:38 PM | #2 |
SUA... sounds like something that Paul would do...
How about a non-drop pitman arm??
01-22-2010, 07:00 PM | #3 |
You beat me to the pitman arm idea. Does he want to change the ride height?
Ian 06 Toyota 4Runner |
01-22-2010, 08:34 PM | #4 |
change the shackles out to a boomerang style or longer possibly.
01-22-2010, 11:00 PM | #5 |
From the second picture it looks too me like there is a problem with the springs. The shackles are pushed way too far forward to be sitting in stock position.Look at it from the side. and maybe measure the springs and axle location on the springs ?????
Shawn |
01-24-2010, 09:17 AM | #6 |
Where would a TRE flip put you????
