Poll: Dana 44 or 60?
I am trying to decide on which axle to use in a 2006 jeep rubicon unlimited. This jeep will see a decent amount of road use as well as serious rock crawling. Lift will be 5-6" and tires will be 37 to 39's. Should I keep the stock 44's and upgrade the shafts or throw in dana 60's? What do you think and why? Thanks in advance!
I vote for the 60. I know a bit about you and you will end up with the 39s. Also, the Rubicon 44 has 30 ends (Unit bearings, BJ, etc)
Plus, depending on the timing, I could use it in the front of my YJ ![]() ![]()
what are the 44's worth? rear needs to be checked out but so far I would say the passengers side axle shaft flange is bent.
The Pirate
I would not push over 37's with the stock 44's! Even then you may want better shafts and u-joints if your lookin at heavy weight 37's. 39's on 44's = broken junk every trip.
