90 cherokee engine swap
I just did a engine and grabs swap on a 90 cherokee 4 0 and when I turn the key on I have power put turn to start it. It don't do anything put the starter works fine and don't hear the fuel pump running please help thanks
grabs swap???
what year motor went into it? what all did you use from the old motor / new motor? you DID use the original flywheel, right? |
one more time......?
The 90's have the goofy little box that all the wires go into near the battery. some big relay or something. I had a problem with mine burning up, check that stuff over around it for connections, juice.
Did you get it running????
Those dang grabs will mess you up everytime....:confused: :confused: :confused:
It would be nice to have more info to help you, and there are plenty here with knowledge to help. |
