Air shock debate
Sway away racerunner 2.0x18 or Fox2.0x18 which is the best shock I`m building a single seat toy axled buggy with chevy v6,tf 904 ,Klune,dana 300.So it should be pretty light weight.Any input is appreciated
Thanks Jeff |
I haven't used either so I can't comment on that, but IMHO 18s are too much shock for a small toy axled rig.
we have used both...they both seem to work really well...i like the racerunners because they have a thread on cap that protects the valve... but as far as function i dont think one is any better than the other..
I'm sure he's referring to there unpredictable body roll and unloading that necessitates a sway bar on atleast one end of your rig... especially on a pig like Mikes.
I've been in two buggies with air shocks and hated how they performed in both. There cheap , that's a plus and I've heard they can work pretty good in light/little rigs. |
sorry for off topic but what torque convertor are you going with jeff?
tf 904
Ok whats this turd out of....
i like saw, had 3 sets. never had fox though. id say threr all the same.
id be curious to see how you plan on getting 18 inches of travel from a narrow toy axle...i had 16's and had to limit it to 14 in the front, even with a narrow single seater and spacers, a tire still rubbed. post up a build pic, for sure. |
I have 16" sway a ways with toy axles. It's very hard to get that much flex out of the front end. I would suggest 14" in the front. I've had good luck with the air shocks just have to play with the oil levels until your happy.
Willys buggy 4.3, 350 trans, toy axles, linked suspension, air shocks |
if you put some thought and design your suspension correctly, air shocks wont be a prob on your light rig. mine was a joy to drive- would flex awesome but could corner on quad trails at 30 mph.
a hacked suspension design can make your truck very unpredictable. |
#12 |
O the memories....
fabricator |
This message has been deleted by fabricator.
