Old 04-02-2010, 11:46 PM   #1
Rod End Question...
I am trying to decide between Johny Joint type rod ends or hiems. I have found that buy the time you but everything needed for hiems, you are oretty close to the price of Johny Joints.
My question is do I need JJ's at both ends of my links or can I run bushings at the frame end and JJ's at the axle end?
Thanks!
Old 04-03-2010, 12:28 AM   #2
JJ's at both ends if your budget allows for it. You won't be happy long term with the bushing at one end, unless you like slop, noise, and binding during flex.
Old 04-03-2010, 10:48 AM   #3
Thanks!
Old 04-03-2010, 11:04 AM   #4
I have a set of weld on cartridge joints for sale if your interested..I prefer the threaded collar over the snap ring of a JJ.
Old 04-03-2010, 07:22 PM   #5
This jus came to mind....will JJ's on each end flex enough? Seems like the joint housing would hit the mounting tabs?
I know that I will get 45 different answers but here goes....Johny Joints or Hiems? If Hiems, what size is recommended?:confused:
Old 04-03-2010, 10:06 PM   #6
tinbeater
tinbeater's Avatar
It will be fine. I have JJ on both end and dont get no were close to bottoming they out.
