Old 04-30-2010, 04:43 PM   #1
Nuts's Avatar
4.3 knocking...
ITS NOT THE ROD OR MAIN BEARINGS!!!! But there is a loud knock coming for my 4.3. The motor is a 97 or 98, is there anything thats known for hammering on these?
Old 04-30-2010, 05:46 PM   #2
is it knocking the same in neutral as in gear with a load?
Old 04-30-2010, 06:58 PM   #3
If it's an auto, maybe loose torque converter bolts, or cracked flywheel.
Old 04-30-2010, 07:15 PM   #4
that is what mine is doing beed that way for over a year , I'll second Casey's diagnosis , I'm going to dig in to mine while it's under the knife and see what it is . Load doesn't change mine knock.
Old 05-01-2010, 08:51 AM   #5
Nuts's Avatar
Load doesn't change it, and all the convertor bolts are tight and the fly wheel is good. I know this because i just put the motor in... Its kind of a high pitched knock, and I'm starting to think the crank is hitting the windage tray in the oil pan.
Old 05-01-2010, 04:56 PM   #6
I had a 4.0 ford knock like hell for about 10 minutes once when I first installed it. I wouldn't have given you two cents for it and was about to yank it back out of the truck. Then I thought what the hell, what have I got to lose and revved the hell out of it. It got quieter. I pushed it a little more and it finally got very quiet and was an extremely good motor for about 4 years. I know this is probably the exception to the norm, but I feel that the engine had some power steering fluid or tranny fluid that ran down in the intake, as it was sitting at a junkyard under a shelf with other engines above it that created a hot spot, or detonation point when I started it, hence the knock. That is the only way I can explain what may have caused it as it truly ended up a great engine.
