Old 05-27-2010, 06:42 PM   #1
tom tom
tommy
tom tom's Avatar
Send a message via Yahoo to tom tom
wiring the back lights
Ok i got everything hooked up right so im told by someone who know a little about wiring buti still have no running turn or brake light and i know nothing about wiring lights can anyone help me point me inthe right derction its a yj 94
tom tom is offline   Reply With Quote
Old 05-27-2010, 08:48 PM   #2
SixFtUnd
Danny Beach
SixFtUnd's Avatar
do you want it done right or do you just want it to work ??? haha on my bronco I spliced into the headlight wires and ran from there to the back it had no tail lights when I got it
I'm sure you want more professional job but that will get you lights
86 Ford Bronco
Old 05-27-2010, 09:29 PM   #3
tom tom
tommy
tom tom's Avatar
that still wouldnt give me brake lights right
Old 05-27-2010, 10:29 PM   #4
check were they split in the rear for the two lights, mine had a short right there and was a little gremlin to find. other than that you have the lightis in and wired to oem specs? leds or factory lights?
Old 05-27-2010, 11:57 PM   #5
dan
gotta love middletucky
dan's Avatar
His lights are after market led and whoever put them in cut the factory harness and just wired them in that way they are not grounded to the body or frame its kinda a wiring nightmare
Old 05-28-2010, 07:43 AM   #6
jfiscus
jfiscus's Avatar
Get a test light and run a new good ground wire. then turn on your running lights and connect the test light between the "for sure good ground" and the wires. The one that is hot (test light lights up) is your running lights, repeat prochedure for left turn signal & right turn signal, etc. Good luck!
