Old 05-28-2010, 11:41 PM   #1
fordman00
fordman00's Avatar
rear end pop/click
I was wondering if any of you guys would have an idea why my truck is making a clicking/popping noise. It sounds like its coming from the rearend. I dont do burnouts or anything, but it does have 33's on it. Its a 97' F150 4x4 4.6L V8
Old 05-29-2010, 12:11 AM   #2
kb9qdi
Storm Chaser
kb9qdi's Avatar
U-Joint? Worn Cross Pin? Worn Carrier? Loose Suspension part? Loose or broken Sway bar links? The list can go on.......
When or what makes it happen?
Old 05-29-2010, 10:08 AM   #3
fordman00
fordman00's Avatar
i dont think its the u-joint.Sometimes it does it when you back up, and sometimes when you take off and maybe a time or two after youve taken off.
Old 05-29-2010, 10:13 AM   #4
SixFtUnd
Danny Beach
SixFtUnd's Avatar
where are you located?
86 Ford Bronco
Old 05-29-2010, 10:48 AM   #5
kb9qdi
Storm Chaser
kb9qdi's Avatar
Crawl under and see if there's play in the rear drive shaft. You'll here a clunk if the carrier or cross pin have some wear on them causing a driveline clunk when the slack is taken up starting and stopping.
Old 05-29-2010, 10:33 PM   #6
fordman00
fordman00's Avatar
I already did that and theres no play.
Old 05-29-2010, 10:33 PM   #7
fordman00
fordman00's Avatar
Im at college near Athens.
Old 06-03-2010, 06:53 PM   #8
fordman00
fordman00's Avatar
was the rear ujoints.thanks everyone
