3 Link Question...
I am having to 3 link the front of my Sammy-ish rig due to clearance issues. My question is, should the upper (frame) mount for the panhard be to the inside or outside of the frame?
Thanks! ![]() |
Put it outside, that way the panhard bar can be as long as possible and won't pull the axles to 1 side as bad when it drops out. Also if you have normal steering(not full hydro) keep the panhard bar parallel with the drag link.
#4 | |
![]() That little thing on the bottom of the engine called the "oil pan"... ![]() |
REverse the triangulation of the bars that aren't clearing the pan... there shouldn't be any reason it wont clear...
fark 3 links and panhards... they are the suck. might as well run a radius arm setup.
