Old 06-04-2010, 07:13 AM   #1
Cribbetr
Dana 30 high or Low pinion
I have a 91 YJ I'm wanting to replace the stock gears 3.07 with 4.10 I know I need a bigger carrier. The question i have is how do I tell if I have a high or low pinion.
Cribbetr is offline   Reply With Quote
Old 06-04-2010, 08:27 AM   #2
RuffedUpXJ
RuffedUpXJ's Avatar
WEll high pinion reffers to the pinion being on top on the axle center line. So High pinion is nicer to have since your driveshaft starts out high on the axle, farther away from the rocks and also lesser angles on the drive shaft.
Also, I think yours should have a low pinion from the factory. So an upgrade would be the high pinion but they mount differently since a XJ has coils in the front and your YJ has leaves.
Old 06-04-2010, 10:13 PM   #3
91 YJ is High pinion 30
Old 06-07-2010, 10:13 AM   #4
I think the Low-Pinions started with the TJs & XJs of the same year that they started making TJs. ('97?) Anything prior to that was a HP D30.
Old 06-07-2010, 11:09 AM   #5
RuffedUpXJ
RuffedUpXJ's Avatar
My bad, i guess i shouldn't trust quick searches on line.
