Old 07-20-2010, 10:22 AM   #1
brake lines
i have a 98 tj in the shop right now and all the metal brake lines and the fuel return are shot (rust) just wondering if anyone has any suggestions on where to get a prebent possibly stainless kit at. i have dealt with classic tube on old cars but havent called anywhere yet. suggestions?
thanks scott
Old 07-20-2010, 11:24 AM   #2
Classic tube carries jeep kits as well... in fact, 4wd carries that same kit from classic tube...
http://www.4wd.com/productdetails.aspx?partID=8247
ah, and an omix/ada kit here as well....
http://www.4wd.com/productdetails.aspx?partID=58749
Old 07-20-2010, 11:49 AM   #3
thank you. i was wondering about them just hadnt had the time to look. i have seen 3 98 tjs that the lines were junk on so i dont know if they(jeep)has learned anything from that
thanks again
Old 07-20-2010, 01:17 PM   #4
KennyTJ
The Pirate
KennyTJ's Avatar
The "green" hard brake line stuff at NAPA or any of the parts stores is hand bendable now days and is awsome stuff. You can get long enough sticks to handle any of the single line runs on a Jeep tub. We re-did the YJ and "moved" the lines to a better location than the factory run. Stuff also blows away the cost of the pre-bent lines as well.
Just my 2 cents worth.
Old 07-20-2010, 01:37 PM   #5
yes but factoring in the labor cost to do someone elses when you own a business is important....it would probably be cheaper to buy pre bent ones...just my .02
Old 07-20-2010, 02:12 PM   #6
agreed.
Old 07-21-2010, 12:57 AM   #7
The "green" hard brake line stuff at NAPA...
That's what I used to mate my 96 master with my 89 prop valve.
It did bend okay, but I had a hell of a time flaring it. I ended up having to scrape off all the green coating to get a grip on it...
