Old 08-17-2010, 07:40 PM   #1
mossyoaktj
mossyoaktj's Avatar
95 cherokee overheating
dad has a 95 cherokee with the 4.0 in it. its been having overheating problems. so far he has replaced thermostat , raditor, good waterpump. he just dropped a good little bit of money and too the head off replaced the head gasket. and.....still the jeep is overheating. any ideas
UNITED STATES MARINE
Old 08-17-2010, 09:34 PM   #2
BiggDaddy
BiggDaddy's Avatar
check anti-freeze?
This sounds simple, but have you checked the anti-freeze? That was the problem with mine, all I had to do was add some green stuff, again and again. Turned out to be a hole in the radiator, but some goop stopped that. Haven't had any problems since.
Good luck!
BiggDaddy
'82 CJ-7, 6" lift, stock axles
258, 35x15.50x15 TSL/SX
Rustoleum Gray
BiggDaddy is offline   Reply With Quote
Old 08-18-2010, 01:32 AM   #3
mossyoaktj
mossyoaktj's Avatar
Good luck!
BiggDaddy
yea he has also flushed the system as well.
Old 08-18-2010, 01:37 AM   #4
Fan clutch?
When does it overheat?
Old 08-18-2010, 05:40 AM   #5
mossyoaktj
mossyoaktj's Avatar
Fan clutch?
fan clutch is good, and it has electrical fans as well. dad says it tends to overheat a lot on the open highway
Old 08-18-2010, 08:19 AM   #6
RuffedUpXJ
RuffedUpXJ's Avatar
With it being on open highway, where there is plenty of air flow across the radiator, that the water pump is the suspect since it isn't spinning as fast as running through the gears say hitting 3k or so but only hitting just over 2k. Or you may have a build up some where. POssible take the water pump off and have a look at the veins and make sure nothing spun.
Also, whats over heat to your dad? pinning the gauge or riding at 210?
