Old 09-06-2010, 04:10 AM   #1
mossyoaktj
mossyoaktj's Avatar
gear selection
im lookin at upgrading my gears in a few months i want to move to bigger tires. i run 33's now with a 373. but im lookin at ordering the 8.8 ready to bolt in from east coast gear supply (http://eastcoastgearsupply.com/i-276...-assembly.html) so i can get rid of my weak 35c. i want to wheel 36s and will most likely have another set to run on the street probably around a 34-35. trying to figure out which gear selection i need to go with. my jeep has the I6 and 5spd. i want something to meet in between a good trail gear and a good road gear seeing how i will have to drive from NC to Ohio a few times seeing how my next unit is in camp lejeune. and ideas. i already have a 373 an up carrier for the dana 30 which will be upgraded before too long if plans go as i want them
UNITED STATES MARINE
Old 09-06-2010, 09:48 AM   #2
My opinion for a daily driver is to gear it for optimal street use. Having the right axle gears for cruising on pavement and pulling grades on the freeway are much, much more noticable versus off-road when you can rely on using low range.
Old 09-06-2010, 11:14 AM   #3
I have 4.56 in mine. It is a good compromise. 4.88 would be good offroad and 4.10 would be a bit tall for the road.
Old 09-06-2010, 12:04 PM   #4
4.56 would also go well with my "why would you only go up one step" rule...
from 3.73... if 4.10 is good, then 4.56 has to be better...
my dos pesos
Old 09-06-2010, 12:13 PM   #5
mossyoaktj
mossyoaktj's Avatar
yea i was leaning towards 456 or 488. i have the 373 now with 33s and dnt mind them probably cause i just came from 307s but goin up to a 35 to 36 im regearing again when i get my 8.8 and what not. i just dnt want to go too deep into gears with it being a street trail vehicle.
Old 09-06-2010, 12:24 PM   #6
Trigger
I had 4.10s in my Rubicon running 33s and wish I would have had 4.56s. Just a better gear for the application.
