09-08-2010, 02:11 PM | #1 |
solid trackbar upgrade
i found this just searching around like usual and i didnt recall seeing neone running this set up for the track bar. its a solid way to help prevent that unwanted death wobble that we all kno n love. so id thought id share. its a track bar kit from clayton that gets rid of of the weak joint on the frame side.
http://claytonoffroad.com/product_in...64e6b6372eec6c
09-09-2010, 01:33 AM | #2 |
Ready to Wheel!!!!!!!
When I broke the stock bar on my Ram, I decided I did not need the curve around the diff so I went solid. Before it would wobble at about 35 mph, after I could drive it 70 down the interstate with no issues on 39.5" IROKS. Of course that's before welding the rear.
I would suggest it to anyone if they have the clearance for a straight bar.
09-09-2010, 01:54 AM | #3 | |
09-09-2010, 11:45 AM | #4 |
The Pirate
Yea, a lot of manufactureers have gone to the bracket to rotate the mounting of the Hiem joint to horizontal vs. verticle. The factory used a tie rod end, so the verticle mount made sence, but a heim joint wears out quickly in that position, my RE sure did! Rubicon Express, X-Factor, Rough Country... you get the point all offer a bracket with thier front trackbar now.
09-09-2010, 12:02 PM | #5 | |
i want to get something will be a good upgrade and help to control death wobble, the jeep was getting death wobble on a regular basis when i was last home, i made a few adjustments to cover it up some so this winter when i get back im upgrading the whole the steering system. would the clayton track bar still be a better option over factory with the RE track bar do you not need to use the drop bracket on the axle side like you do with the oem track bar and does go the same with all aftermarket hd track bars?
UNITED STATES MARINE 99 TJ, locked, long armed, creepy's Last edited by mossyoaktj; 09-09-2010 at 12:26 PM. |
09-09-2010, 12:13 PM | #6 |
ok so looking at the rough country track bar. its a more than hundred less htan the clayton. i kno the phrase "you get what you pay for" but is there honestly goin to be any quality difference in the two. i notice the mounts are different, the clayton bolt to the factory mount and also welds the frame where the rough country mounts by drilling and putting bolts throught the frame, and i would honestly add welds to help strengthen it up more
09-09-2010, 03:49 PM | #7 | |
The Pirate
I will most likely make mine. |
09-09-2010, 11:52 AM | #8 |
None at all, it does great. I can't say I've taken it easy either.
I used one existing rod end with about 4 inches of the original rod. My machinist didn't have left handed threads the size I needed so we milled down the shaft, slid on the ends, and welded in place. And for a nice, smooth look we milled the welds back down. Been over a year ago and I'm still pleased.
