Old 09-14-2010, 12:57 PM   #1
BIGRAM
Ready to Wheel!!!!!!!
BIGRAM's Avatar
Busted transfer case---HELP!!!!
I just found out I have busted my transfer housing in my '95 Dodge Ram. Is there another direct bolt up that is beefier, does anyone have a stock replacement, or what is a decent price for a used one?
360 cui, auto
Trying to get before Slade this weekend, any help is very appreciated.
1994 Dodge Ram 5.9L SWB
Old 09-14-2010, 01:28 PM   #2
kyrel69
one from the cummins trucks should be a upgrade. I just do not know if it will bolt in or now.
Old 09-14-2010, 03:22 PM   #3
BIGRAM
BIGRAM's Avatar
I don't believe it will without some mods. I'll look into that for the future, Thanks.
Salvage yards around here are wanting $450. I found a fellow with tranny and transfer I may be able to deal with.
Old 09-15-2010, 02:09 PM   #4
BIGRAM
BIGRAM's Avatar
Can anyone tell me why my old input shaft is longer than the one I am planning to use? Will I have any issues?
The old one is the shiney one and tail of transmission. The dirtier and rusty one is the one I just picked up.
ID:	2833   Click image for larger version
ID:	2834   Click image for larger version
ID:	2835   Click image for larger version
ID:	2836   Click image for larger version
ID:	2838   Click image for larger version
ID:	2839   Click image for larger version
Old 09-15-2010, 02:59 PM   #5
kyrel69
well the shorter one will not have as much engagement on your output on your tranny.
It looks like there is a lot of difference in the lenght in those 2 you might not even engage it at all.
you could swap the inputs on the transfer cases to make sure it works right but that would be a lot of work
Old 09-15-2010, 04:38 PM   #6
I'm assuming they are both the same Dodge 23 spline (if I recall correctly)...
I would MUCH rather tear into a t-case and put the right input gear in than have less than normal engagement... Looks like there will be very little overlap... that sux.
