Old 12-05-2010, 11:11 AM   #1
Project Coppertop Axle Swap
Picked up some axles yesterday.Even with the snow falling and the ground a snow/muddy mess ,I manage to cut the axles out.
Dana 44 front and Dana 60 rear out of a 1979 F250. Paid 300.00 :)
Now ,let the adventure begin.....
Old 12-05-2010, 02:00 PM   #2
nice... I bet you'll sure miss those 7 minute Dana30 axle changes, won't you?
Old 12-05-2010, 02:11 PM   #3
lky13blazer
lky13blazer's Avatar
Great deal on the axles....hopefully by spring I'll be doing my yj.I'll be following this one for sure
lky13blazer is offline   Reply With Quote
Old 12-05-2010, 03:40 PM   #4
Is a disc brake swap on tap for the rear?
Old 12-05-2010, 06:21 PM   #5
You know it..Changed out way to many...
For sure,Already been researching..Thinking bout these...
http://bluetorchfab.com/store/advanc...42u0&x=10&y=11
The build sheet is in the works.
Old 12-05-2010, 06:22 PM   #6
boomhauer
boomhauer's Avatar
lky13blazer...if you are going to do the same to yours then i have a '79 ford rearend that you will want. $100.00 and it's yours. it is complete.
Old 12-05-2010, 10:15 PM   #7
lky13blazer
thanks I'll keep it in mind but it will be at least after the first of the year before i get to...do you know the gear ratio? and bolt pattern?
