Old 12-15-2010, 07:07 AM   #1
NKYJEEPSTER
NKYJEEPSTER's Avatar
tire sidewall repairs
Anyone know a place around Cincy that can fix a hole in the sidewall of a tire? I got a pin head size hole in a tire looking to get it repaired.
Old 12-15-2010, 10:12 PM   #2
pitracer1
Jammin Jim
pitracer1's Avatar
Send a message via Yahoo to pitracer1
there is a place in milford, its on meijer drive. off hand cant think of the name but its on the left hand side.
pitracer1 is offline   Reply With Quote
Old 12-15-2010, 10:30 PM   #3
kb9qdi
Storm Chaser
kb9qdi's Avatar
Most shops won't repair a sidewall due to saftey but......some will, mainly independent shops. Options.....
Tube it, cheap but I personally wouldn't run on it everyday. Good for a spare in my eyes only or for a trail rig.
Try and pull thru patch plug....may/may not work.
Find a shop that vulcanizes sidewalls. Can be Pricey but usually works well,again I still wouldn't trust itfor a DD. I repair/sell tires for a living and have tried sidewall repairs for many fellow off roaders and most hold for awhile but usually fail over due time. If it's a tire your going to depend on every day I'd replace it and be done with it. Trail rig, I'd try the repair or use it for a spare. If it fails your not running 70 mph on the express way risking yours and everyone's life.
Some will say go for it no mater but I wouldn't on a DD. I see them fail everyday from sidewall flex and heat buildup. Usually when a tire runs low on air the sidewall heats up and the rubber gets soft/fails damaging the tire and or the sidewall making it unrepairable anyway.
Good Luck
Old 12-15-2010, 11:40 PM   #4
underpowered
They call me......Scuba
Pull through patch plug is what i have always had luck with on a sidewall.
as the above said, i would not DD a patched sidewall tire, must more prone to failing than a typical tread patch. use it as a spare if it is on a driver.
beat up rusted out k5
Old 12-16-2010, 01:31 AM   #5
http://www.cincyoffroad.com/forum/sh...ht=tire+repair
Old 12-16-2010, 09:11 AM   #6
jlynch
I have had 2 sidewalls repaired at Bob Sumerel tire in Dayton Ohio. They are used for offroad only but they are still holding air just fine. If you have a bias ply tire it will be easily fixable. One of my tires was a radial, they was able to fix it but it looks like ****. Price is reasonable also, hell of a lot cheaper than a new tire. Here is the address.
Bob Sumerel Tire
7711 Center Point 70 Blvd.
Dayton, OH 45424
Phone: (937) 235-0062
Fax: (937) 235-0064
Old 04-16-2011, 07:30 PM   #7
For those I've asked about this topic, I found the thread. Will call tomorrow to ask. I'll probably call the Milford one..though now I wonder if Dayton is closer to me. hmm
Best One Tire of Mid America Service manager Pete Waits 513-248-3900.
Old 04-17-2011, 10:14 AM   #8
KennyTJ
The Pirate
KennyTJ's Avatar
I had a nearly new IROC with a sidewall cut repaired in Milford at Best One, and it looks NEW! No problems, it is a bias tire, not sure if that makes a difference. They do the sidewall repair at the retread/recap shop.
I have had no problems, saved a $300 tire!
Old 04-17-2011, 01:05 PM   #9
tinbeater
tinbeater's Avatar
If you go to Milford ask for Steve blankenship
Old 04-18-2011, 11:29 AM   #10
Now to see how a 35 fits in the trunk of an x90
giggle
Old 11-06-2012, 05:39 PM   #11
Time to dig up an old thread. Cut a side wall and took it to best one. They didn't really want anything to do with it but said they would try. We will see.
Old 11-06-2012, 05:45 PM   #12
Puckett at Shotgun does them.. a damn good job too
Old 11-06-2012, 06:00 PM   #13
Jonesy
Jonesy's Avatar
Got any contact info for Puckett? Slit one of the tractor tires on the yota. Tried patching it and didn't hold up.
JT Jones
83 Toyota - beater
87 Toyota Truggy
Old 11-06-2012, 05:46 PM   #14
Good luck. They told me the same thing on a tire I had. I told them it was an offroad only tire and if they could not fix, atleast they tried. They did not touch the tire.
LIKE IT OR LEAVE IT!!!
Old 11-06-2012, 06:37 PM   #15
I'm interested also of this doesn't work out
Old 11-06-2012, 08:45 PM   #16
Todds # at Shotgun Fab is 567-1117. In Verona right off 42 at the Boone/Gallatin Co. line.
Old 11-06-2012, 08:51 PM   #17
He can hot vulcanize a tire ?..
Old 11-07-2012, 06:13 AM   #18
Yep. As far as I know he has never had a return and I've seen him repair some nasty cuts. One was as long as a dollar bill and started in the bead. It wasn't a cheap repair but when your paying $400+ dollar's/tire sometimes it's just worth it.
Old 11-09-2012, 07:06 PM   #19
Took my tire to best one in Milford on Tuesday. Their Customer service is horrible. I still have not heard if they can fix It or not. Every time I call, they say they have to call the retread shop and they will call me back. They never call me back. Then when I call again I get the same line. Getting a little frustrated.
Old 11-11-2012, 08:55 AM   #20
Wow must have changed since I had mine in there. I went to the Fleet Manager and not through the customer service line. Sorry to hear...
Old 11-12-2012, 02:11 PM   #21
Called today. First thing he said was sorry I dropped the ball on this one they're working on it right now. They can fix it that's all I care about.
Old 11-12-2012, 02:33 PM   #22
That's good anyway..
Old 11-12-2012, 04:01 PM   #23
Outstanding!
You know how much I like waiting for tires...
Old 12-10-2012, 01:06 PM   #24
Find another place to fix your tires. Still waiting. I'm glad I was able to find another set for a good price. I dropped it off on November sixth as of today they have no idea what's going on with it
Old 12-10-2012, 01:41 PM   #25
That sucks!
