02-09-2011, 12:10 PM | #1 |
ballistic joint questions
i have a chance to buy 16 ballistic joints 1-1/4 shaft 5/8 bolt hole 2.60 width. they are brand new but the old weld on shank style. i have heard some issues with the welds failing and was wanting some feedback from people. they are complete with the inserts and jam nuts all still packaged up and i can save ALOT over the new style for all 16 but if they dont hold up well its not a good deal. told him i would let him know tomorrow so teell me what you think or heard.
thanks scott
One of these days Zuk 2.0 |
02-09-2011, 01:06 PM | #2 |
if the package says defective do not buy it. ;) How much will your rig weigh that these are going on?
02-09-2011, 01:06 PM | #3 |
I have the 3.0 ones on my lowers. Weld on, no shanks, so probably dosent help your question... Probably wouldent recomend them based on what ive heard and seen since ive got them though but I could be wrong
02-12-2011, 02:22 AM | #4 |
i use to run ballistic fab joints but i would not recommend them. they just wear out too fast in my opinion and it gets old really fast having to adjust them all the time. currie is the way to go
02-12-2011, 10:37 AM | #5 |
Sounds like I would steer away from them unless you are putting them on a seriously light weight rig. :confused:
02-12-2011, 10:00 PM | #6 |
thanks for the replies. i am going to pass on them because of some things i had seen and just wanted to know if it was isolated happinings. only a good deal if they will work.
02-13-2011, 11:12 AM | #7 |
has anyone checkd out tk1 racing? 1.25 complete heims 45$$$ I used ruff stuff speciaties but buddy showd me the tk1 heims
