Old 02-20-2011, 07:32 PM   #1
Hotwheels
Hotwheels's Avatar
Toyota Rear disc brakes issue
So I just put 4340 axles and rear disc brakes on my 94 4runner. I had to put a new booster on it and rebuild the front calipers. The problem I am having is the brake pedal feels like **** after I have blead the brakes. I dont have any leaks in the system. The rear brakes are sky-manufacturing rear disc set up with Chevy calipers and stainless lines running on the rear axle. I have a porportioning valve and 10lb residual valve comming off the master for the rear brakes. The only thing I can think of is I have a air pocket some where in the system and it has just not bleed out yet. Any thought or comments would be great.
Rob
Old 02-20-2011, 07:38 PM   #2
to my knowledge a stock brake master cyl is big enough for the rear disk setup..i.e. it makes for a spongey pedal...we usually put a master cyl off a 93 yota t100 non abs on em and it works great...hope it helps...maybe someone else can help more??
Old 02-20-2011, 09:45 PM   #3
sounds like air
that have a 1" bore master on it?
always bleed farthest corner to the nearest to the master.
bleed porportioning valve last. if it had one
sounds like u dont have anymore
fyi...these trucks r the hardest units i have ever had to bleed
Old 02-20-2011, 10:06 PM   #4
Hotwheels
Hotwheels's Avatar
yes has 1" master on it
Old 02-20-2011, 10:07 PM   #5
Try a pressure bleeder if you can get access
Old 02-21-2011, 07:59 AM   #6
Hotwheels
Hotwheels's Avatar
I have power bleed the brakes on my 4runner. The only thing I can think of at this time is I am using my stock ABS master cylinder and the rear part of the master is to weak and I need to change it to a non ABS master.
Old 02-21-2011, 06:11 PM   #7
Hotwheels
Hotwheels's Avatar
So here is what I did today with the brakes. I have a 1" bore non ABS master cylinder on my 4runner. I have no proportioning valve and no 10lb residual valve on it at all. Took it all of to make sure it was not them. The runner had rear ABS and it is not hooked up at all. I have speed bleed the brakes and 2 person bleed the brakes and still have a ****ty pedal with the truck off and it goes to the floor when it is running. I am so fing pissed at this thng. I have also call sky and talk to someone there and he told me that everything I have done they would have done. So I am sunk any help would be great.
Rob
