03-04-2011, 03:33 AM | #1 |
Yota axles questions
Ok, I have maxed out my sami axles and I keep braking stuff...
specs: 5.38 gears lockers front and rear chromoly birfs calmini hd rear axles disco brakes in rear 4.1 tcase gears on 9.50x16 ag tires. now looking around it seems that the 85 yota axles 4.10 are the ones to find and get for a new swap out. what is the most bang for my buck to upgrade on the yota axles to get something close to what i was running with the sami axles? 5.29 gears? chromoly axles and birfs? weld rear and detroit locker front? pro/cons ? trail gear lockout coversion? 6 shooters? oh yeah still running tracker p/s with mod pump and cooler. Any issues that some one can see that I will need to swap some thing out for the steering (full hydro but not in the budget yet...), braking,etc...
Thanks, 67fastback ------------- 84 Honda cr60r - for sale 87 Honda 200sx - for sale 67 Mustang fastback - under restoration MCA #63430 04 Silverado 2500 crew cab 87 sami - "SPLAT" 87 sami tin top - "Blue Fire" 88 sami - "Squirt" My New Video Channel -http://www.youtube.com/PhillbillyProduction My Video Channel - http://www.youtube.com/justworkn |
03-04-2011, 09:20 AM | #2 |
Diesel guy
wonder if you were thinking of selling the sami axles :confused:;)
2013 RZR S |
03-04-2011, 10:33 AM | #3 |
Im by no means a yota guru, but I had built toy axles in my rear engine moon buggy, and had a lockrite in front that caused me headaches, so I would steer clear and stick with the detroight idea..
03-04-2011, 11:53 AM | #4 |
Yea lockrites are junk. I got a yukon grisly and it works great. And for axels, longfields are the the best. I run 39.5 tires and Ibeat the hell out of it and NEVER broke a axel or had any problems out of locker.
03-04-2011, 01:06 PM | #5 |
Sorry to hear you guys have had bad luck with lockrites... I agree the suck in the front, but i have run them in the rear of every Landcruiser i have ever had... The longfeilds are about the only thing i would put up front for an axle upgade, the warranty is the best you will find...
If you want to find more info on the Yota stuff look on IH8Dmud.com ... Here is a link to the Yota mini truck section http://forum.ih8mud.com/79-95-toyota-truck-tech/...
03-04-2011, 01:17 PM | #6 |
Longfields are the only axle to run. I run 38 sx's and never had any problems. I'm not easy on them either.
Willys buggy 4.3, 350 trans, toy axles, linked suspension, air shocks |
03-05-2011, 05:36 AM | #7 | |
4.62 gears, locked front spool? welded rear, rear disco setup with anti wrap (tractor supply) bar. need one chromoly and hub ( locker bolts sheared off) maybe brake pads or calipers on front not sure I took this apart when i need parts for splattt..
03-05-2011, 06:08 AM | #8 |
also are the stock yota's
27 spline or 30 spline, I did see the longfields- 645.00 vs the dirty 30 - 579.00 they both seem to be made from same material not much a price difference.. so most say go with the longfields!! are the creaper flanges a good upgrade? pros/cons? http://www.trail-gear.com/hubs-and-drive-flanges they seem like they would be..
03-05-2011, 10:33 AM | #9 |
Phil I just bought 30 splines because of the halloween trip where I brkoe 2 stock inners, so my chromo 27 spline longs are for sale with good inner shafts, $200 for both. With the short tire you have you won't break an inner 27 spline
edit: the one weakness yota axles have is TECHNO music, its something about the crappy repetitive beat that causes them to fail... |
03-05-2011, 08:32 PM | #10 | |
yeah right!
03-06-2011, 02:23 AM | #11 | |
Diesel guy
2013 RZR S |
03-08-2011, 02:41 AM | #12 |
pm sent!
