Old 03-17-2011, 11:35 PM   #1
postaldave
Yoda Monster :full blown fj40 rear steer tube buggy
WANTED: FJ40 window frame and a good hood.
LATEST PIC
LATEST DRAWING
Large pile of 70s Jap rust
Double frame rail tube chassis
3800 super charged V6
904 trans
5.1 atlas
Raceline wheels
40/17 maxxis trepador tires
60 front w/PSC steering, Dynatrac chromoly shafts and joints, Dynatrac Hubs, Detroits w/5.13
60 rear w/PSC steering, cv shafts and joints, Detroits w/5.13
alu links johnnies on lowers, hiems on uppers
PRP seats
Griffin radiator and coolers
Vintage heat and air
Fiberglass hood, fenders and grill
most of the work is being done by Richard at The http://thehobbieshop.com/
Hard to say what it really is. It not a frame build since everything is tubed. Not really a tube buggy since it has a boxed cab. It will have some exo cage and some not. A real mixed up beast, just like I want it.
The build started out as a 4link on my YJ(pictured in the back of the second shot), in record time it got way out of hand. I took the jeep apart for the build and then decided that an FJ build would be better. Being a tube buggy it doesn't need much of the original truck the FJ laying outside of Richard's shop seemed liked perfect match.
At that point i dragged the FJ in and tore it apart.
Then Richard built the subframe for the drivetrain and for something that the body could
mount to. Dimple died engine mounts are sweet. Not really needed and you can't really see them but that is how he does things. Lots of cool touches if you look real close.
Then the REAL cutting began and it's not even close to being chopped yet. Richard cut
it up and put enough together to start framing the build.
The next big cuts will be under the door. It will have a major boat side with cutting board skids. Trying to keep it a low center of gravity, the design is centered around being able to slide over and threw stuff with ease.
I didn't want a full SUV like an FJ40 but the FJ45 offered way to little room in the cab.
When bouncing it freaks me out having metal and glass so close. Also will let me move the seat back and have room for stereo junk and a cooler inside the cab.
The back is shorter then an FJ40 but longer then an FJ45. Basically an FJ45 king cab.
Maybe an FJ46? If there was such a thing. ;)
After that I put the hood and tires on to get an idea of the look. Me liky!
Tires in the pic are not spaced like we will have it and the whole buggy will be a little higher. Total of 116 wheel base is what we came up with.
Next update will have the boat side and the body tied in. Not sure when but there will also be a 6 to 8 inch square bed on the back to balance the look of the front hood.
postaldave is offline   Reply With Quote
Old 03-17-2011, 11:37 PM   #2
postaldave
ere is the latest goings on for the FJ project.
For the sides we went with a huge boatside and tapered them. This cut out most of the rust
and gave me the boatside I wanted. The tapered was added to deal with the FJ body that has
a taper to it. Along with matching that it serves a really cool function. When buggy is on a
rock on the boat side it will push the rear UP and OUT. This makes it more like a race boat
design rather then the basic john boat often put on a buggy with a boatside.
If you look close you can see Richard dimple the body mount. He really loves that tool and
not afraid to use it. :) I think it's cool as hell too. :jam
Keeping the rig with a very low COG it has to be able to slide very well. While the rig will look
like the width of a normal FJ in fact, the bottom will be VERY narrow and with the steep boatside
it should cut threw rocks like a boat in water. Putting on cutting board like skidplates will help.
I'm still not decided on the sides, having the cutting board stuff like i'll put on the bottom will
likely be the best. I'm thinking running aluminium on the boatside for looks. Not sure how much
drag compared to the cutting board material.
It will look like the rig will have ZERO floor space with the sides like that but in fact Richard
will be cutting in as channel on the floor for legroom. The center console will be higher and
will divide the interior like a rally car. One of the nicest touches is the door jam. Eventhough
the doors are cut way up they still will seal and keep out water and other stuff from coming
into the cab.
and finally the rear window. Just going with a plexi rear window an most of the time
just open but having a nice channel to put it in will be nice. Now that is what i call a rear truck window!
Old 03-17-2011, 11:46 PM   #3
postaldave
not that great a picture but as you can see there is LOTS of room left in the cab. even with
the huge boatsides the floor space is more the roomy.
that kinda looks like an FJ now :lol:
well that is pretty much it boys, believe it or not this this is heading off to paint. the exo is going to
be put on after that and most of the work done when it comes back. worked out a deal for a guy to
do all the prep work and paint. i really didn't have any plans to make it look that nice but
a good deal couldn't be passed up. so let the fun times begin.
Old 03-18-2011, 01:19 AM   #4
I read your thread on MUD and you are going to have a swwet ride there... I think you can still call it a 40... Can't wait to see it on the trail...
Old 03-18-2011, 09:17 AM   #5
Nice ride. I have a '71 sitting in storage back home for one of these days.
Off topic, but what are you doing with the side glass from the top?
Old 03-18-2011, 12:34 PM   #6
postaldave
Only using the corner glass. The big window and front window were both cut and pushed together to make that onw small window. I'll just use sow plexi for that.
I still have the small windows and the big ones I'm not sure if I took them out right or with a big hammer.
You looking for parts or wondering what I did to make the cab?
