Old 03-18-2011, 03:26 PM   #1
android
The right lift?
Hey guys I have a Wrangle with new 31/10.5 Goodyear Wrangler MT/R.. I'm ready to pull the trigger on a lift and want some advise as to the right lift for my jeep and me..
I'm hearing Rough Country is the best brand?
I'm thinking of their 3.25" spring & shock combo?
Also looked at their 4" spring,shock,link,& control arm combo?
Is the 4" lift too high and will it reduce comfort or drivability?
Will the 31" tires look small if I use the 4" lift?
Is the 3.25" lift enough?
I wheel the jeep on occasion.. Now that I have bought the tires I want I'm going to wheel it more the lift will complete the deal.. We also use this vehicle to drive every day so I want to keep it as streetable as possible..
android is offline   Reply With Quote
Old 03-18-2011, 04:59 PM   #2
Trigger
Not sure who told you that Rough Country is the best brand because the consensus is that it has "rough" in the name for a reason.
Adding a lift will not help you wheel any better. You're still going to have the same clearance regardless of whether you raise the Jeep 3 inches or 10 inches. The primary use of a lift is to allow you to run bigger tires so you can get more clearance. Adding a lift is only going to raise or center of gravity.
Personally, I would run it with the stock suspension and see how it does. You'll be surprised how much better it goes with a more aggressive tire.
Old 03-18-2011, 05:55 PM   #3
8UP
4" lift with 31" tires? Yep, it'll look goofy. Have fun with 31's and no lift, save up for the lift and tires at the same time.
Old 03-18-2011, 06:15 PM   #4
android
Thanks for the info guys.. Im stil wanting to lift it up a couple inched to keep my tires from rubbing.. They rub pretty bad when I turn.. Can anyone recommend the right lift to remedy this?
Old 03-18-2011, 06:29 PM   #5
everyone will have there own opinion on this subject. i have used almost all of rough countrys stuff and only had a couple of there 2.2 shocks leak which they warranteed quickly. i have a 6" long arm kit on my 05 lj and i think its very good and rides nice. they are not the most expensive but i think very good for the money and still in business.
Old 03-18-2011, 06:30 PM   #6
U could sawzall out the body ;) probably wont earn u style points, but would free up the money ud put into a lift, then u could add f&r lockers..... And chrome windsheild hinges(to earn back those style points)..
You dident mention the year or condition ofthe wrangler
Old 03-18-2011, 07:04 PM   #7
android
It's a 2000 has a few dings on it but I still wash it.. Ha ha. That's how I draw the line on wether it's a nice car or not.. If I'd still wash it.. Paint is still shiny and never wrecked.. I want to put up a pic of it but I haven't been savvy enough to do so from my phone..
Old 03-26-2011, 11:06 AM   #8
adamkn
I think the problem is that your tires are rubbing on your control arms when you turn all the way to the right or left. You dont really need a lift-kit to fix this. There are a few different ways to take care of it, but the easiest thing to do is adjust your steering stops. Here's a write-up to explain how it's done, along with some pictures:
http://www.4x4xplor.com/steerstop.html
2000 Jeep Wrangler Sport
adamkn is offline   Reply With Quote
