Old 03-21-2011, 03:01 PM   #1
Project Low and Lean Rustbucket ( LLR )
Ok , not going to be a lot of info in this thread but figured it would be a good place to keep track of photos and ......
I got a 94 YJ in trade for labor on another rig. It's a stocker with a 4.0 , stick , and it has some rust issues to say the least.
My plan is no lift , 33" tires , high line front fenders and alot of cutting and trimming, boat sides , flat belly with motor and gas tank protection and full cage. Will be a sunday woods beater and all around mall crawler....
On with the photo's
speed holes right?
Houston We Have a PROBLEM
And the cutting begins :
more to come !!!!!
Old 03-21-2011, 03:16 PM   #2
Big tires and no lift... Likin that!
Old 03-21-2011, 03:41 PM   #3
Why am I seeing all these rotted out Yjs? My frame is still perfect. I dont get it.
Old 03-21-2011, 03:48 PM   #4
thats what I was saying last night ! My YJ frame was in great shape, but I have fixed prolly 4 or 5 of my buddies...... This Jeep even came out of Ky ?????
Old 03-21-2011, 10:07 PM   #5
cincygman
was looking at Wranglers before I found my XJ, most were rusted pretty bad underneath????
Romans 7-8
Old 03-23-2011, 09:01 AM   #6
Back to the rust and wieght reduction program, Been slow moving because of other projects and work , but I did get a chance to get the passenger side boat side cut out .... I can't wait to get it filled in and then plated !!!!
I have to tell on my self ....
I went out the other day and started cutting with my plasma cutter and about three minutes in to it my plasma lost arc.... had good ground and air was coming out .... but no cut :confused:
I turned it off and spent the last few days wondering how much it was going to cost to fix it .... Then yesterday I got off work and was getting ready to take my sons car to get inspected when I noticed the front tire was low. I grab my air hose and start putting air in the tire and notice that I had very low PSI in the hose........
I don't know about all of you , but I NEVER turn my compressor off ........ well someone did . I goning to blame it on the wife :mad:
I still didn't put it together with the plasma cutter .... Later on last night I get home and start woeking on the Jeep when a buddy stops by for a beer. I start to tell him about the plasma cutter when ...... the light bulb came on .... OH SH*T !!!!! no air pressure ..... Sure enough the plasma has to have at least 70 PSI ......
OK enough talking, plasma still works I'm happy and the Jeep is lighter because of it.
Old 03-23-2011, 09:16 AM   #7
RuffedUpXJ
RuffedUpXJ's Avatar
Looking good Mike, you keeping the Jimmy?
Old 04-06-2011, 10:13 AM   #8
dovetail complete minus final body work.
Crappy pic but it was late and I really didn't feel like doing anything but clean up and go in for the night....
I also took the top section ( pad ) off the dash . going to make a filler panel with defrost vents that is part of the spreader bar on the "A" pillar. I just can't stand how the dashes stick up higher than the tub.
Old 04-06-2011, 05:59 PM   #9
BIGRAM
Ready to Wheel!!!!!!!
BIGRAM's Avatar
I like it!!
1994 Dodge Ram 5.9L SWB
Old 04-07-2011, 11:01 AM   #10
Got a fair amount of work done last evening , nobody bothered me all night , ended up working till around 3:00am .... cough cough ... made work rough this morning but hell , I miss the all nighters wrenching in the garage.
Any how , got the exhaust ran , had to weld up the header ( typical 4.0 crack) I ran 2.5 back to a Thrush muffler and turn down , all tucked up nice and close to the floor pan.
I removed what was left of the factory skid pan I'm suprised it was even still under it ....
I had first said I was going to Highline the front and I changed my mind and went with tube fenders.... well in typical Sarge fashion I changed my mind last night about midnight Highline it is . I also did some more tube work on the cage. I will not be able to get much more done for several days with my schedule , so this is it till next week.
Old 04-07-2011, 11:07 AM   #11
just to compare , highline vs. tube :
Old 04-07-2011, 12:49 PM   #12
RuffedUpXJ
RuffedUpXJ's Avatar
Looks good Sarge, you going to put the 30 under the Jimmy?
Old 04-07-2011, 12:57 PM   #13
Yep the 30 and 35 are going under the Jimmy with the 33" TSL's . Going to lower it a little bit and see what I think . May sell it , May keep it . Might look at trading it for a quad or towards a side by side ????
Old 04-07-2011, 09:21 PM   #14
tom tom
tommy
tom tom's Avatar
Send a message via Yahoo to tom tom
looks good cant wait to see it done
08 jeep Sahara soon to be with 33s
tom tom is offline   Reply With Quote
Old 04-14-2011, 09:19 AM   #15
Well , after having to go to Newark for a three day waste of time :mad: , I finally got back to work on the rig . Got the cage final burned in , but I might add a bar or two in the back .... floors are all welded up and filled in , going to paint the cage today and then line the floor .. one more go around with filler and primer and it's paint time. Speaking of paint .... I have changed paint colors
cage, crusher corners, boat sides and bumpers will be hammered silver and the body will be Sub-lime green pearl .
I went to the paint store to get paint for my sons car and fell in love with the color .....
Old 05-06-2011, 09:46 AM   #16
just for fun , some pic's from start date ( 3/21/11) to last night .
Old 09-07-2011, 11:33 AM   #17
You sure have had some dark clouds over ur build...
Its gonna get better now. I can sense it. I'm lookin forward to this phase of ur build. Keep them pics comin
Old 09-07-2011, 11:43 AM   #18
BadHabit
BadHabit's Avatar
Should be a nice stance, low and wide.
BadHabit is offline   Reply With Quote
