05-05-2011, 07:41 PM | #1 |
h3 hummer rims questions?
will h3 hummer rims fit on yota axles ? if you cut out the center hole?
:confused: trying to find some 16 rims 6 lug.... next question who can cut out a 4 in center hole in alum rim?
Thanks, 67fastback ------------- 84 Honda cr60r - for sale 87 Honda 200sx - for sale 67 Mustang fastback - under restoration MCA #63430 04 Silverado 2500 crew cab 87 sami - "SPLAT" 87 sami tin top - "Blue Fire" 88 sami - "Squirt" My New Video Channel -http://www.youtube.com/PhillbillyProduction My Video Channel - http://www.youtube.com/justworkn |
05-05-2011, 10:04 PM | #2 |
you can look for some factory toyota rims... There are a couple different styles, from a newer Taco or 4runner... but i think the widest you might find is 8" wide...
05-05-2011, 10:34 PM | #3 |
well i picked these up and found that the center hole is 3.85 in well I could just grind out the lip to make it 4 1/4" (108 mm) and it will fit over the hub. but the best new is I got 3" wheel spacers and it does not let the rim go back far enough to hit the hub so it is all good with grinding anything and I can still use the hummer center caps. all is good!
Thanks, 67fastback ------------- 84 Honda cr60r - for sale 87 Honda 200sx - for sale 67 Mustang fastback - under restoration MCA #63430 04 Silverado 2500 crew cab 87 sami - "SPLAT" 87 sami tin top - "Blue Fire" 88 sami - "Squirt" My New Video Channel -http://www.youtube.com/PhillbillyProduction My Video Channel - http://www.youtube.com/justworkn Last edited by 67fastback; 05-07-2011 at 04:03 AM. |
